Old 04-13-2008, 01:48 PM   #1
rdlohr
Default My Sexy TREXY 500, finally! (Build Report)
After months of homework for all the mods, I've finally finished my TREX 500.
The build took a long time and I found that I had to do many more mods then were required for either my 450 or the 600 builds. Some of the mods were required and some I just wanted to do. Ultimately, I’m really happy with the quality of the completed bird.
I tried to stay top end on the components since I have found that spending more up front usually costs me less long term and I am generally more happy with the heli. I didn’t follow this to an extreme though since I didn’t opt for a Jazz ESC on this build.
ESC: Stock Align
Cyclic Servos: JR Z3650s x 3
Tail Servo: Futaba BLS251 Brushless
Gyro: Spartan DS760
Component placement is always critical for me so I built off of all the lessons I have learned from the 450 and the 600 as well as lots of Helifreak input. Here are rules I generally try to balance while laying out components. Most of these came from Finless Bob years ago with an associated EEEK.
1) Isolate high current noisy components (Main Battery, ESC, and motor) from low current parts (Antenna, Battery, gyro, gyro controller, and receiver)
2) Protect all components from crash damage
3) Make heli parts you replace regularly easy to replace (Bottom Plate, Tail boom, belt, tail pulleys, etc)
4) Keep wiring runs short
5) Protect all wiring
6) Assure continuity from head to tail. (Newly added rule with this build)
Here's what I came up with:
I avoided running any wiring through the boom block area so it could be easily removed. I ran the wires on the outside through this area.
Side views with no canopy
The receiver and gyro were combined into one Electronics Module. It’s completely protected inside the rear of the machine and easily removable as an entire unit. This allowed me to minimize the wire runs between these components. I couldn’t use one of my TREX500 gyro trays since the Futaba receiver has its plugs on the top so I made a variant tray that slides in the back. The rear two plastic bottom plate screws secure it in place while allowing it to be easily removed. I was trying to avoid any rewiring when I have to swap out the plastic bottom.
When shortening the gyro to rudder servo run, I included a drop down diode under the shrink around the tail servo connector.
The ESC was placed inside the front to protect it and minimize high current wiring. It fits under there with no altering of the stock ESC wires like it was made to fit. I'll keep watch on that area for heat since both the motor and ESC are heat generators. I used a similar approach with my TREX 600 and have had no problems with it.
The ESC control line is isolated to one side away from all the servo runs. Each servo wire was run in its own sleeve to allow easy replacement if a servo dies. The Elevator and rudder servo wires were shortened, but the aileron and pitch servos were just barely long enough. I left some slack in the wiring in back to allow me to wire the Electronics module while shifted out the back.
I opted for a Revolution Whip this time just to try something different than the Deans. I used the antenna bobbin approach that OICU812 showed me while building my 450. I still use my 72 MHz receivers since they have served me well and I’m kind of waiting for the 2.4 radios to mature a bit. Notice also that I never run any wiring below the skid mounts because I have often seen the skids ripped off in a crash.
I opted for the Spartan DS760 gyro and Futaba BLS251 brushless tail servo (thanks OICU812) since I really want a locked in tail and was willing to pay a bit more to get it. Since the BLS251 is a full sized servo, I had to use a TREX 600 tail servo mount with the TREX 500 boom rings. I've seen others grind the 500 mount and make it work. I did use a drop down diode since this servo expects a 4.8 volt input and I wanted to drive my cyclic servos with the higher voltage. I was a bit worried about COG with the larger tail servo, but with the canopy mod and overall component layout, it balances perfectly without even having to move the battery down on the it's tray.
Since ESD is an issue for this heli, I did a number of things to minimize it. The main thing I did was make sure I had conductivity from head to tail through my frame and metal components. I did all the following mods to limit ESD:
1) Use metal tail and assure conductivity from shaft to boom. I used a file to scrape off the anodize just under the screws where the black plates connect to the silver frame. I also sanded the inside of the tail assembly where the boom enters. I filed the paint off the boom at both ends.
2) Copper foil on boom block to assure conductivity from boom to pulley to frame. The copper foil feeds way down into the hole for the cross tie so that when the cross tie pushes in it makes good contact. I filed the top edge flat across like a waterfall where it first goes into the cross tie hole.
3) Made frame into Faraday cage. I have no real proof that this mod helps and it took a few hours of work to do. I'm using it as a test bed to find ways to reduce ESD. I would not recommend others to re-create it. I in fact have already removed parts of it since the copper is thin and gets damaged easily when changing things.
4) Boom stop mod to keep it from hitting the belt
5) Metal cross ties in the boom block
6) Metal main bearing holders
Finally, I did ChasHeliCops canopy mod to make adequate room up front for my battery and linkages. This mod is sweet. I’ve never had a canopy fit more perfect.
ChasHeliCops thread: http://www.helifreak.com/showthread.php?t=63835
Many ask about the wire braid. I put sleaving on all my wires to protect them from rubbing on edges and to hide any splicing. I take off the connectors using the tip of an exacto knife blade to release the catch on each one.
I used flexo clean-cut that I bought years ago:
http://www.techflex.com/prod_CCP.asp
Many use this:
http://www.readyheli.com/SearchResults.asp?Search=braid
You put the sleaving on first. I used 1/8" and 1/4" depending on how many wires I was running. It can be bunched up to make the inside diameter increase so that you can easily slide wires through it. Bunch it like an accordian and keep sliding the wire through. Slip some heat shrink over the ends after ward. Put the connectors back on then shrink the tubing. I bought an assortment of heat shrink sizes from Home Depot and used the size that was just bigger than the sheathing.
If you have to lengthen a run, you can buy servo wire extensions and then cut off the socket end and splice in the new wires. Put shrink around the individual wires to isolate them. You can shorten runs by cutting off the connectors then replacing with new ones.
http://www.servocity.com/html/servo_...s___leads.html
There are kits available to put on new connectors.
I use this one:
http://www.hansenhobbies.com/product...orkits/ck_sck/
I opted not to do the following mods:
1) Ground the motor mount to the ESC or battery negative. I prefer to leave my electronics floating with respect to the frame. I will ground it via a resistor or fuse if I later find I have problems.
Warning: Do not ground your frame or motor mount to the negative of the battery or the ESC without using something to limit current in case a short occurs.
2) Rollers to keep the belt from hitting the boom. I like this mod but I won’t do this unless driven to it. My 450 and 600 belts rub slightly too and I’ve never had a problem with them.
Docjoe's mod: http://www.helifreak.com/showthread.php?p=623511#post623511Jetleaf's mod: http://www.helifreak.com/showthread.php?p=628696#post628696
Things to be aware of when building:
1) Had to dremel some plastic away on the plastic bottom in front of the motor on one side to get the frame to lay flat
2) Set screws in the skids leave ugly thread marks in the white plastic
3) Boom needed to be shortened (may have been from the metal tail) http://www.helifreak.com/showthread.php?t=67456
4) ESD problem and associated mods http://www.helifreak.com/showthread.php?t=62101
5) Tail rudder linkage had binding till I filed it a bit. http://www.helifreak.com/showthread.php?p=628344#post628344
6) Was difficult to get Spartan in programming mode because I had to plug in the Deans then quickly start toggling switches. I would prefer they give you an extra second or so. Spartan was simple to set up once I got it into setup mode.
As usual, Bob’s vids were invaluable. I found the Spartan vid particularly helpful. Thanks to all the many Helifreaks I borrowed ideas from and bounced ideas off of.
Bob's TREX 500 Build Link:
http://www.helifreak.com/showthread.php?t=53304
Bob's Spartan DS760 Setup Link
http://www.helifreak.com/showthread.php?t=47240
7) Some had had problems with the screws stripping out. Do yourself a favor and get the set of Align Drivers and you most likely will have no problem.
http://www.helifreak.com/showthread.php?t=84114
The other option is to replace the screws. Heres a good link:
http://www.rcscrewz.com/product_info...oducts_id/2745
Another great resource for ESD and build stuff by ChasHeliCop:
http://www.helifreak.com/showthread.php?p=827592#post827592
All in all, it turned out pretty nice. I can’t wait to get out and fly it. It seems to be an overall solid bird and the size seems perfect.
Hope you like it!
Rick
Edit: Oct 4, 2008 Scorpion 1600KV Motor Upgrade:
I bought the Scorpion Motor and a Scorpion ESC back on father’s day when my family knew they wanted to get me heli stuff but didn't know what to buy. My stock Align motor squealed from the first day I powered it up. The squeal went away for a long time, but it had been intermittently doing it recently. I had been flying with it all season so I really don't feel bad about retiring it. Since I was going to the Heli Phenom, I figured it was as good a time as any to give the Scorpion a try.
I reused my 13T pinion since that seemed to be a good tradeoff between headspeed and flight time. I'm mostly a sport flyer anyhow (not by choice ).
The ESC connectors were different than the stock Align version so I had to solder new connectors on my ESC. I didn't put new connectors on the motor since I wanted to be compatible with the Scorpion ESC when its time to upgrade my ESC. Hopefully it will just plug right in.
The biggest changes were caused by the fact that the Scorpion is an out runner. Since the outside motor case spins, you can't locate wiring next to the motor or it will get chewed up. Strategically placed nyties solved this problem and overall the switch over went without a hitch. Here's some pics.
ESC Motor Lines to the right, and control line to the left. I ran the control line above the motor to keep with my philosophy of keeping the bottom plate easy to change in the event of a crash. The only wiring I have under the heli is my 72 MHz antennae.
Right Side showing routing of ESC control line over the top of the motor:
Left side showing nyties I used to assure the wires never migrate to the pinion or spinning motor casing area. Everything seemed to stay in place on its own but I used some nyties to be absolutely sure.
Closeup of the ESC Motor lines:
I took it outside under the spot lights and hovered a bit and it sounded perfect.
Enjoy!
Rick
Helifreak, the place to be!
Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X
My products, flown by top pilots around the world, like you!
Last edited by rdlohr; 04-27-2009 at 08:06 PM.. Reason: Added Scorpion Motor Upgrade
rdlohr is offline        Reply With Quote
Old 04-13-2008, 02:13 PM   #2
kraaijer
Nice and usefull report Rick!
Goblin 630, Vibe 50, trex 500, 450, mcpx v2 and mcpx bl. All fbl of course...:-)
kraaijer is offline        Reply With Quote
Old 04-13-2008, 02:54 PM   #3
schwaggs
Thanks Rick! A couple questions:
What did you use to mount the BLS251? Is it a stock T600 servo mount?
Where did you get the conductive paint/pen for the frame sides?
How did you get the copper foil to electrically connect with the hex bolts?
How did you connect the copper foil from to boom to the frame?
schwaggs is offline        Reply With Quote
Old 04-13-2008, 03:05 PM   #4
Jetleaf
Very nice indeed. Good job Still working on mine but she's coming along just fine.
I put the "__" in lazy
Jetleaf is offline        Reply With Quote
Old 04-13-2008, 03:31 PM   #5
Moreflying
If that 500 falls out of the sky, lightning struck it or you looked away. It looks great, well thought out with attention to details. Great reference for other too.
Moreflying is offline        Reply With Quote
Old 04-13-2008, 03:36 PM   #6
MTDV
Very detail report. I cannot wait to get mine (sometime next week). My nitro is so noisy and messy. Thanks for the pictures.
To schwaggs,
You can get everything at either Fry's electronics or Radio Shack (speicial order for conductive pen).
MTDV is offline        Reply With Quote
Old 04-13-2008, 04:27 PM   #7
rdlohr
Yes, its a standard 600 mount with the rings from the 500 mount.
Radio Shack. They had it shipped in from a store that had them.
I did this but it really isn't required. It does make really good connection though.
This link has further detail:
http://www.helifreak.com/showthread....conductive+ink
I filed a little flat edge on the hex hole then let the foil drape over that edge and way down into the hole. When I pushed in the aluminum cross tie it fit snug against the foil.
See the pics. The copper strip against the boom connects to the copper strip for the one bearing that also goes to the aluminum cross tie. I soldered the strips together.
Here is a link for further detail:
Old 04-13-2008, 04:31 PM   #8
rdlohr
Thanks all!
Lightning, LOL! I like that!
Actually, I'm pretty good at thinking up ways to make helis fall from the sky!
Rick
Old 04-13-2008, 04:33 PM   #9
rdlohr
I got to maiden it today and all I can say is WOOOOOOW!
This bird is way more 600 than 450. I like it!
Rick
Old 04-13-2008, 04:43 PM   #10
Super D
how did you shorten the wires on your spartan?
Fly it like you stole it!!
Super D is offline        Reply With Quote
Old 04-13-2008, 04:46 PM   #11
dragoljub
Looks Great! As soon as the TT comes out im ordering mine!
dragoljub is offline        Reply With Quote
Old 04-13-2008, 05:16 PM   #12
d3sbo
verrrrrrry clean install
2 x Blade MCPX,stock & duel Brushless
Trex 250FBL,BeastX,Scorpion,Trex 450,Scorpion,4s,Jazz esc,Trex 500FBL,3GX V3.1,5s,Scorpion
Avant, Kasama head,OS 91 OMI,XeroG Raptor,Total G,Outrage Head
Trex 600 EFL Pro super combo,BeastX
d3sbo is offline        Reply With Quote
Old 04-13-2008, 05:23 PM   #13
docjoe
Rick,
Great job! It looks like you've taken the best of what's been out there and made them your own. Plus you've added some nice touches elsewhere! Looks good and probably flies great.
Joe
"Chancho, when you are a man, sometimes you wear stretchy pants in your room."
-Nacho Libre
docjoe is offline        Reply With Quote
Old 04-13-2008, 05:33 PM   #14
rdlohr
Its easier than you would think. Cut that bundle open and you will see. There are no joints under there. It just routes wires to different connectors. Darn, I wish I would have snapped a picture of that. I just put on new connectors where I wanted them.
Rick
Old 04-13-2008, 07:22 PM   #15
rdlohr
Originally Posted by docjoe View Post
Rick,
Thanks much. You gotta love the freak!
Rick
Old 04-13-2008, 08:15 PM   #16
ChasHeliCop
Dude, you are Rockin' now, No wonder it took so long, well the painting too.
Sponsored by Visa/MasterCard / Team Budweiser / Trojan Field Rep
Donut Connoisseur
HELI-FREAK, You couldn't have picked a better place to land !
ChasHeliCop is offline        Reply With Quote
Old 04-14-2008, 01:52 AM   #17
rdlohr
Thanks!
Never paint any room in your house. It starts a domino affect ...
Rick
Old 04-14-2008, 02:41 AM   #18
psindrup
You rock dude! Very, very, very nice and "clean" build.
You will for sure have a glitch- and problem free bird.
Respectfully
Peter
psindrup is offline        Reply With Quote
Old 04-14-2008, 04:08 AM   #19
jurassic5
top notch build report.
great job.
Never Underestimate The Power Of Stupid People In Large Groups
jurassic5 is offline        Reply With Quote
Old 04-14-2008, 06:18 AM   #20
Eduardo
Wonderful details. I can see you take pleasure where others would just go by.
Very clean, and helpful. Enjoyed most the wirings treatment.
Eduardo
AURORA 90 / VELOCITY 50 / T-REX 600E PRO / T-REX 550 - HITEC AURORA 9
Eduardo is offline        Reply With Quote
