Old 04-15-2008, 09:59 AM   #41
JaggedEdge
Beautiful bird rick. Thanks for sharing your build info. Looking forward to going through your build again when I do mine... someday. Much appreciated.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 -
JaggedEdge is offline        Reply With Quote
Old 04-15-2008, 12:54 PM   #42
rdlohr
Originally Posted by muscleflex View Post
nice heli!!! i'm jealous!
noob question....what is ESD?
Electrostatic discharge (ESD) is the sudden and momentary electric current that flows between two objects at different electrical potentials. The term is usually used in the electronics and other industries to describe momentary unwanted currents that may cause damage to electronic equipment.
Read that link I provided to see how it affects the 500.
Rick
Helifreak, the place to be!
Rush 750 w/VBAR,Logo 400SE, 600SE w/NEOs, TREX 450SE, 500, 600, Blade mCPX,130X, 180CFX, Nano QX, MiniProtos w/BD3SX
rdlohr is online now        Reply With Quote
Old 04-15-2008, 10:05 PM   #43
rdlohr
Originally Posted by mk1spitfire View Post
put it in a sticky?
Originally Posted by michael503 View Post
ditto
Officially stuck.
Rick
Old 04-17-2008, 03:48 PM   #44
Socal500
IMO.. Way overboard but nice work.
Socal500 is offline        Reply With Quote
Old 04-17-2008, 04:18 PM   #45
rdlohr
Thanks, I agree.
Rick
Old 04-18-2008, 04:13 AM   #46
Finless
Team Taco VP
Yea.... I wouldnt want to crash that and spend 3 weeks fixing all the mods
Reminds me of years ago when you built a RC Airplane from a "kit" box of sticks. Now do that with a SCALE airplane from a box of sticks! 6 months to build it and detail it and when you crash you just CRY.... I built ONE scale airplane from a kit box of sticks and when it crashed I never did another....
My Trex450 is still flying with a crappy looking crashed and repaired canopy... WHY? Seems like every time I put a new on on I crash.... Why tempt fate
Bob
Old 04-18-2008, 04:32 PM   #47
JaggedEdge
Bob
CF booms do that to mine.
Old 04-21-2008, 07:36 AM   #48
muscleflex
Rick
thanks rick
muscleflex is offline        Reply With Quote
Old 04-25-2008, 10:17 PM   #49
rdlohr
LOL. I never plan to crash it ...
Rick
Old 05-29-2008, 03:26 PM   #50
heli4fun
Hope you never crash, but the fact is nobody "Plans" to crash !!!
heli4fun is offline        Reply With Quote
Old 05-29-2008, 04:46 PM   #51
rdlohr
LOL. Just kidding. Everything is actually designed to make rebuilding easy other than the Faraday cage part which I probably wouldn't rebuild.
Rick
Old 05-30-2008, 11:56 AM   #52
heli4fun
Rdlohr,
I think I am going to do my first flight tomorrow with T-rex 500, it took me about 2.5 months to finally finish it (time just did not allow...) but the good thing is I applied many mods from different post in here, and of course I did use your mod for the tail boom (the copper tape, scraping the paint ,.....). I also added my own Canopy mod to accomedate a FP 3300mah Lipo , fits with no problem and perfectly balanced !!!
All I need to do get some advice on how to setup the "Fail safe" option in X9303 in case ......
Anyway thanks for the helpfull posts and pics.
Hrair
Thanks for
Old 05-30-2008, 12:13 PM   #53
rdlohr
Rdlohr,
Hrair
Thanks for
Thats great. Glad I could help! You're gonna love it!
Someone else will have to help with the X9303 since I have no experience there. If you don't get input here, just start a thread and I'm sure someone will jump in.
Rick
Old 05-31-2008, 09:42 AM   #54
Socal500
Rdlohr,
Hrair
Thanks for
See here... http://helifreak.com/showthread.php?t=76755
Old 05-31-2008, 10:42 AM   #55
rdlohr
Thanks Socal500!
Rick
Old 06-03-2008, 09:30 AM   #56
SeanOC
Hey Rick a couple of questions..
First can you confirm for me that on the boom stop mod you grind the notch down that prevents the boom from rotating? (and on the opposite side as well) That leaves the boom stop on the top and bottom and not on the sides, correct?
Also when grounding the boom block did you only apply copper foil to one side or both? The way I see as long as the boom is grounded to the pulley bearings on on side all is well but can you confirm that?
BTW I am using one of your gyro mounts, nice job!
Sean
T500CF: 9650's, JR 770/ 3500g w/ step down, stock motor and esc, torque tube, alum upgrades, kasama tail w/ heim joint CW's , radix main and tail blades
SeanOC is offline        Reply With Quote
Old 06-03-2008, 04:40 PM   #57
rdlohr
I ground the notch down half way so there was still enough to keep the boom from turning and yes there is enough of the end stop left on the top and bottom. I view the mod to keep the belt from hitting as optional. If you defeat the VDG, all should be well. That means grounding the pulleys together through the boom. Some would argue you only need to do the tail end but I preferred both.
Theoretically, you only need to complete the circuit so one side would work. However, since the circuit is completed through a bearing, its an intermittent connection. Since you are just trying to drain off the voltage buildup over time, that should be OK, but its easy enough to do both sides at once so I did. (I'm referring to both bearings, not both sides of the boom block)
Glad you like my gyro mount! I've got all good feedback so far from customers.
Good Luck,
Rick
Old 06-03-2008, 06:35 PM   #58
ChasHeliCop
Rick, I am so glad you posted this, I just read through it again, and can see it has gotten alot of people on the right track. Kudos Dude !
Hopefully, you prevented alot of replacement parts from being consumed.
Sponsored by Visa/MasterCard / Team Budweiser / Trojan Field Rep
Donut Connoisseur
HELI-FREAK, You couldn't have picked a better place to land !
ChasHeliCop is offline        Reply With Quote
Old 06-03-2008, 09:03 PM   #59
rdlohr
LOL. Thanks man! The on line vendors are scowling at me. Something tells me they are getting plenty of business from us freaks anyway!
Rick
Old 06-04-2008, 12:14 AM   #60
aaron07
Rick,
Very nice build. Thanks for documenting this whole process. Great sticky.
How heavy is your Trex 500 inc. battery?
8S Trex 500 3026-1000KV, Jazz 55 10 32, Sportbec, 3 9650mg's, Vistabi V Bar V4 / JR8900.
8S Trex 600esp 4025-890KV, Jazz 55 10 32 with heatsink, Herc HC/HV bec, 3 JR8915's, Vistabi V Bar V4 / JR8900.
aaron07 is offline        Reply With Quote
