Old 01-08-2013, 02:22 AM   #301
lamhe
OK, Thanks Chuck.
I think i managed to set it up anyway by watching Bob's head setup sequence, nearly the same. Will be interesting to se if i manage to set up GP900 gyro with DX7s.
Thanks again. rgds Henrik
lamhe is offline        Reply With Quote
Old 06-25-2015, 06:28 AM   #302
msallua
Thank you Bob, Excellent videos!
Align 700N DFC, 105HZ-R // Sab Goblin 700Comp // Sab Goblin 500 // Align 700E DFC HV.// 2x Align 450L Dominator .// Futaba 14Sgh - RealFlight 7.5 - Powered by Pulse - IKON's
msallua is online now        Reply With Quote
Old 07-21-2016, 08:28 PM   #303
wudburns
Default TREX 700 N FBL head linkage
Hi Bob -
I just want to ask if is it okay to use these Linkage rod(E) (Φ1.96x72mm) on Align item HN7064 on my V1 TREX700N FBL head as a swash to blade grips linkage?
I know for a fact that the designed linkage for the head is(Φ2.5x71mm) which are thicker by a .5+mm. Align item [ALI-HN7100A]
Well I'm asking since I have these thinner linkages lying around and planning to use them. BTW I saw the old flybared heads that use the 1.96mm rods. so is it really imperative to use the thicker 2.5mm rod on a FBL head?
Let me know if my question make sense to you sir?
wudburns is offline        Reply With Quote
