Old 09-02-2008, 02:22 PM   #41
ualdrivr
Is it worth it. I think the risk of busting the case or ruining the motor is more than buying a new one when this one goes....MHO.
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote
Old 09-02-2008, 02:26 PM   #42
Aberdeen
Originally Posted by grig View Post
just replaced the bearings in my 500L but I still have the "scream"..................what gives?
What kind /brand of bearing did you use?
In a world of compromise, some don't!
Aberdeen is offline        Reply With Quote
Old 09-02-2008, 03:13 PM   #43
ChasHeliCop
Well, if you do it successfully, it cost you about $2.48 in bearings. plus shipping of course.
Sponsored by Visa/MasterCard / Team Budweiser / Trojan Field Rep
Donut Connoisseur
HELI-FREAK, You couldn't have picked a better place to land !
ChasHeliCop is offline        Reply With Quote
Old 09-08-2008, 02:51 PM   #44
Augman37
Default BOCA REPLACEMENT BEARINGS FOR 500L
Thanks Jarad for the vid on replacing the Stock 500L motor bearings. I struggled a little to find the Boca bearings to replace the stock ones so I thought I would put the link to the set here:
http://www.bocabearings.com/main1.as...00&n=*ENK-227C
TRex 500 CF, AR7000, S9650, S9257 Spartan DS760, all metal part upgrades, TT, Stock ESC/BEC, Hacker A40 10S
Outrage 6S1P 25C 2500mAh and 3300mAh & Zippy 3300mAh
Spektrum DX7
Phoenix Sim on MBP 2.33 GHz Core 2 Duo w/ Parallels & WinXP
Augman37 is offline        Reply With Quote
Old 09-08-2008, 02:53 PM   #45
Augman37
It is actually REALLY EASY to do with just a little care. If you can build a heli that flies, replacing the bearings is no problem with the clear instructions shown on the video in this thread. Thanks again Helifreakers
Spektrum DX7
Old 10-20-2008, 07:49 PM   #46
AzHeliCrasher
I want to try this but I don't know much about which bearing to choose. IE Boca has one of the 5x11x5 starting at a few dollars to one for $24 What is necessary for replacement bearings to be better than stock? I again don't know what is better for the heat, rpm etc
AzHeliCrasher is offline        Reply With Quote
Old 10-20-2008, 08:07 PM   #47
CHOPPER PATROL
I'd suggest you get ceramic bearings from HeliDirect.com. I believe both sizes are available in ceramic and much cheaper than Boca.
I had a friend change mine and it runs much better than stock now I'm shocked.
CHOPPER PATROL
2 - Logo 500SE's, Logo 600SE
DX18
CHOPPER PATROL is offline        Reply With Quote
Old 10-21-2008, 02:38 AM   #48
Aberdeen
Yup, Helidirect has the ceramic kit for about $10.
Old 10-21-2008, 12:40 PM   #49
mk1spitfire
ok, ive had about 185 flights on my stock motor.
How do I tell if the bearings need replacing,can it go on much longer?
I'm spinning the motor pinion and it seems fine. The only notchy feeling is the magnets working.
Secondly, are the bearings a sealed type? ie they don't require any oil? I heard the scorpion bearings need oil after 10 flights????
450 GF Blinged 65hb/401/9650-DX7
500 CF 5245/401/9257 -DX7.
MH150
CX2
mk1spitfire is offline        Reply With Quote
Old 10-21-2008, 12:45 PM   #50
jared_of_atlanta
If you take the motor out of the heli and spin it, it should be nice and smooth - go up to 75%. You may also hear a loud high pitch sqeal when you're flying. I'm pretty sure they aren't sealed.
jared_of_atlanta is offline        Reply With Quote
Old 10-21-2008, 11:36 PM   #51
RC-Bearings
Some motor/ESC combinations "squeal" louder than others and it is just a function of the electronic timing. I have had some brand new motors that were very loud even with perfect bearings in them.
I have bearing kits for the stock motors on my web site.
Paul McIntosh
Stainless, Ceramic and steel bearings
5% discount for the Freaks. Code: helifreak
RC-Bearings is offline        Reply With Quote
Old 04-14-2009, 10:44 AM   #52
gvzwienen
IK heb een vraag welke maat lagers zitten in motor trex 500 ??
gvzwienen is offline        Reply With Quote
Old 04-14-2009, 11:51 AM   #53
jared_of_atlanta
In English?
Old 04-14-2009, 02:43 PM   #54
gvzwienen
I have a question what size bearings seated in motor Trex 500?
Old 04-17-2009, 03:13 PM   #55
ov10mech
Thumbs down Motor Warranty
I have heard Horizon Hobby will take care of you if you send it in. My thought exactly. I am personally not going to take my motor apart after 20 flights to fix a bad product I paid good money for. Mine squeals like a pig even before the first crash. It's fricking horrible. Everyone is having similar issues I know with the 500.
I have one crash on the bird. I am going to put a scorp in it then send this motor in. When I get it back, you will see it for sale in the classifieds.
Originally Posted by ChasHeliCop View Post
Does Align warranty any of their motors ?
ov10mech is offline        Reply With Quote
Old 04-17-2009, 03:42 PM   #56
ChasHeliCop
I ended up replacing mine with the Scorpion 1600 and trashed the stock motor
Donut Connoisseur
Old 05-05-2009, 08:05 PM   #57
esmoglo
Can any one post/make a video on how to lubricate the stock motor bearings without taking it out of the heli?
Angelo
esmoglo is offline        Reply With Quote
Old 05-12-2009, 12:54 AM   #58
Rogerdee
Default Locking the can
In the process of replacing bearings-needed to lock the motor can.
A 450 main shaft fits in the slots in the can.
Use two 450 main shafts to fit the can to a vise-not too tight-you are only stopping it turning.
Use Jarred's way of turning the end cap.
ID:	96582   Click image for larger version
Patience+Perseverance+Paypal=Fix+Fly+Fear
Rogerdee is offline        Reply With Quote
Old 06-07-2009, 09:21 AM   #59
Redfire SVT
I use Tri-Flow in the spray can along with supplied straw to oil the bearings. Shoot a liberal amount of Tri-Flow at the bearings and rotate the motor to work in oil. Do this every 4-6 flights. The bottom bearing is covered by a sticker- cut a hole to expose it. My stock motor has over 150 flights using this method.
Redfire SVT is offline        Reply With Quote
Old 07-04-2009, 02:29 AM   #60
legine
guys please help.....
No matter what I try, the bottom of the motor wont come loose....
Whenever I clamp the motor mount and try undo the bottom...it comes loose at the top, where the pinion is, not at the bottom where it is supposed to.
Ive tried heating it up with a lighter and that didnt work.
I tried clamping the motor really hard with a vice grip but I worked out that doing that also clamps the inside of the motor (which is what Im trying to uncrew) so that method is impossible.
Right now, Ive got my soldering iron resting on the bottom of the motor so it can slowly heat up and hopefully melt the threadlock.
Please help me, I dont know what to do anymore....Im out of ideas
Thanks, Daniel
Daniel
DX7 - Mode 1
TREX 450 PRO!! - GP750 & DS520 - HS65's - AR6100 - Scorpion -8, Align speedy
legine is offline        Reply With Quote
