Old 07-04-2009, 03:52 AM   #61
legine
ok finally got the bloddy thing apart....although Ive made a real big mess, damn green loctite, its not good for anything....only headaches
Im trying to get the bottom bearing out now and I dont have a vice which makes things difficult.
Thanks for the vid, I didnt realise its so difficult.
Daniel
DX7 - Mode 1
TREX 450 PRO!! - GP750 & DS520 - HS65's - AR6100 - Scorpion -8, Align speedy
legine is offline        Reply With Quote
Old 07-04-2009, 08:04 AM   #62
legine
Well after several hours of fighting all I have to show is a busted motor...the bottom bearing was so tight that instead of the bearing popping out, the inner race of the bearing just gave way, so all the little ball bearings fell out and of course all that was left was the outer race which is now impossible to remove from the collar thing.
Really pisses me off that there was nothing I could do about it.
Now for a new motor...
Daniel
DX7 - Mode 1
Old 07-04-2009, 08:11 AM   #63
jared_of_atlanta
Sorry to hear man. Thanks for posting your experience tho.
jared_of_atlanta is offline        Reply With Quote
Old 07-04-2009, 09:53 AM   #64
kqminh
Unhappy
I just get a scorpion 1600kv and fly in this morning , the result not good for me , flying time is down to only 3 min , the power down too, i can not do tic toc , with stock motor I do tic toc very well , my esc is CC 80 , flat curve 100% , timing set 7 (default of cc is 5 ), 2650 mah zippy , so what esc that scorpion motor work good with ?
kqminh is offline        Reply With Quote
Old 07-04-2009, 02:00 PM   #65
jared_of_atlanta
3 min flight and can't do a tic toc? Sounds like something is wrong. My 1600kv and scorpion esc has insane power. What is your head speed? What pinion? How old are the batts?
Old 07-04-2009, 05:57 PM   #66
otto975d
Hey
Jared great video changed my bearings only 1 problem opening was very hard to do but got it everything went smooth put bearings no sweat went do last step and screw back together and realize threads where gone stripped when opening can all well ordered new Tonic motor supposed to be good ever hear of them made by Z power I think
Blade 400 DS287mgs.DS290g.7703d....w/Trex 500 Skids.Esky Lama v4. Phoenix Sim. Trex 500ESP HS5245MGs.3500G.770d AMA#914675
otto975d is offline        Reply With Quote
Old 07-04-2009, 09:57 PM   #67
kqminh
yes , i don't know why , pinion 13 , new battery, next time will try outrage XP 2600 6s, replaced 500L back and the heli rock again , but 500L get too hot , 85 0C after 4 min , I think it will burn out if 5 min, Hacker A40 on the way
Old 07-16-2009, 03:03 PM   #68
golfdad2
Default TREX 500
My TREX 500 motor bearings are going bad. Can you tell me what size I need to order?
golfdad2 is offline        Reply With Quote
Old 07-16-2009, 03:44 PM   #69
jared_of_atlanta
The sizes and part #s are in the video. People have also linked to boca bearing replacements in this thread.
Old 07-16-2009, 04:09 PM   #70
RC-Bearings
http://www.rc-bearings.com/catalog/p...roducts_id=460
RC-Bearings is offline        Reply With Quote
Old 07-18-2009, 03:27 PM   #71
outhouse
great post and thank you!!! ive been chasing a issue with my heli for a week now, in idle up the heli would drift all over and the tail was jumpy. after reading this and watching the vid i checked mine and sure enough the bottom bearing was trashed and the upper wasnt in the best shape either.
lucky i had extra bearings laying around swapping bearings was straight forward thanks to the vid
I found the sealed bearings at finless link but it didnt say if they what abec rating they were. if someone has a link that would be great.
at this time helidirect is out of any usfull bearings.
outhouse is offline        Reply With Quote
Old 07-18-2009, 05:29 PM   #72
RC-Bearings
I have most of the bearings in stock. I can get sealed bearings as well. Mine are all ABEC-3 or better.
Old 07-18-2009, 08:36 PM   #73
outhouse
if you post a link to some sealed motor bearings ill order right now.
i dont want to spend the 19 bucks on these http://www.bocabearings.com/main1.as...n=*ENK-227C-HP
Old 07-19-2009, 04:43 AM   #74
RC-Bearings
Sorry, I only have shielded in stock right now. Sealed should be coming soon.
Old 07-27-2009, 04:36 PM   #75
smegga
Thanx heaps. It's people like you that help make this addiction so enjoyable. Goin off like a frog in a sock !
smegga is offline        Reply With Quote
Old 08-04-2009, 01:23 AM   #76
outhouse
happened to me today. i used a propane torch to heat it up and put a drill bit that barely fit in and slowly rocked it out
you still have your parts?
Old 08-04-2009, 07:10 AM   #77
RC-Bearings
Good idea. I was going to suggest an Easy-Out (for removing broke off screws).
Old 08-04-2009, 07:26 AM   #78
EatMorePizza
Thanks for this info, this is great! I replaced the bearings with Boca Ceramic SS abec Bearings. I bought them directly from boca for like 20 bucks each. I dont use the engine since I got the scorpion, but its ready for back up.
GOBLIN 700 SPEED-KOSMIK200-700XF-NEO-BK CYCLIC AND TAIL
TREX 700E-NEU KDE 1917-12 PINION-NEO -JR 8717 HV CYCLIC-MKS990 TAIL-ICE 160-KDE UNIVERSAL MOUNT W/PINION SUPPORT
EatMorePizza is offline        Reply With Quote
Old 08-08-2009, 08:07 AM   #79
Etraud
Thanks Jared and everyone for this excellent how-to,
It worked for me for the Motor RCM-BL430SP that came on my Trex 450 Pro Super Combo, and in case that could help anyone these are the specs of the bearings.
d = 3.5mm D = 7mm B/T = 2.5mm
and
d = 4mm D = 8mm B/T = 3mm
Everything is possible with the right tools
Etraud is offline        Reply With Quote
Old 08-16-2009, 04:45 PM   #80
XSTAR
Just replaced my bearings, man it was not easy and it was very scary...I will testit out tonight to see if all is ok.
DX8 | TREX 700E | BEASTX | CC80HV | 700MX | AR8000 | HW 15Amp UBEC |
DX8 | TREX 550E | BEASTX | 600MX | CCBEC PRO | 70G ESC | AR8000 |
HELIIMAGE Printed BOOM WRAPS & CUSTOM CANOPY NAME
XSTAR is offline        Reply With Quote
