Old 06-17-2008, 06:49 PM   #1
Mercuriell
Default Bobby Watts Special Stratus Build
Those of you (if there are any!) who don't peruse Bob's tech room may be interested to know we've posted build videos on the new Bobby Watts version of the Stratus. Sections on the fan balancing and dial out may be of interest to other heli builders.
MA Stratus 'Bobby Watts Special' Build videos:
What's in the Box 27 MB wmv
Mounting the Fan 29 MB wmv
Fan removal and dialing in the hub 32MB wmv
Engine and Landing Gear mounting 23MB wmv
Fuel tank and fan shroud - completion lower frame half - 27MB wmv
Left upper frame assembly - 27MB wmv
Gear and clutch assembly - 45MB wmv
Final frame assembly - 32MB wmv
Swash and Servo install - 32MB wmv
Fitting Fan Shroud, Stiffeners and Canopy mods - 25MB wmv
Rotor Head and Main Grips - 50MB wmv :glasses2:
Fixing Rotor Head on Heli and Frame Electrics - 20MBwmv
Tail Rotor Assembly - 46MB wmv
Final assembly - 33MB wmv
Maiden Flight - 9MB wmv
Repair and maintenance as they crop up !
Seesaw repair - 15MB wmv
John
Mercuriell is online now        Reply With Quote
Old 06-20-2008, 02:43 PM   #2
Knud Pedersen DENMARK
Hi John
Great videos.
must have taking alot of time.
ChopperKnud
ChopperKnud,
Team Heliwholesaler - Team Miniature Aircraft
ThePitchbrothers.com
Knud Pedersen DENMARK is offline        Reply With Quote
Old 06-22-2008, 03:24 PM   #3
hi,
I was wondering how many drill up the hole in the upper Collet?
And is it also necessary for the YS91SR?
ChopperKnud
ChopperKnud,
Old 06-23-2008, 03:11 AM   #4
Mercuriell
Good question! - I feel that the OS shaft may be slight bigger on the later versions of the SZ - I really couldn't make ANY adjustments with it tight - as for the YS - I have no idea
John
Old 06-23-2008, 01:38 PM   #5
Hi John,
I will unmount my fan on my YS91SR
I'll let you know the size of the collets and the cranckshaft thread.
PS:
is it best the measure the dial out/alignment, on the top on on the side of the fan?
ChopperKnud
ChopperKnud,
Old 06-23-2008, 01:48 PM   #6
Laurens
I think its best to do it on the inside. A maryland fan would be even better.
Team Thunder Tiger Europe
4RC.nl, Edge rotorblades, Scorpion systems
Laurens is offline        Reply With Quote
Old 06-23-2008, 06:20 PM   #7
chopperben1
Thanks for these vids, I have picked up some great pointers. Really appreciated!
chopperben1 is offline        Reply With Quote
Old 06-24-2008, 04:26 AM   #8
Mercuriell
Originally Posted by Knud Pedersen DENMARK View Post
Is it best the measure the dial out/alignment, on the top on on the side of the fan?
ChopperKnud
I don't think it matters - run out is run out - the inside of the hub, the outside of the hub or the hub face will all reflect lack of centering - it depends a bit on your dial gauge - mine had a plunger which worked best against the face of the hub - some of the lever dial gauges might work better inside the hub. I found the face of the hub to be smoother - there was a little bit of irregularity around the margin of the hub - which hadn't been machined - which made consistent dial readings difficult.
I think both YS and OS shafts are 8mm but the taps are imperial (5/16x28) on the OS and metric (8mmx1) on the YS". It seems the position of the start of the tap from the front bearing that is critical and slightly longer in the YS.
John
Old 06-25-2008, 06:30 AM   #9
Kinger
Great vids! Please keep up the good work. Looking forward to seeing the finished product.
T-Rex 700 with Align 91HZ, Funtech, Rail 696's, Rail 106 tails, Beast X on the DX8.
Kinger is offline        Reply With Quote
Old 10-11-2008, 07:05 PM   #10
LoveMyTrex
is the high ratio stratus on the MA site the bobby watts special version? thanks in advance.
http://www.miniatureaircraftusa.com/...rod=1026%2D2BW
600N 8917HV's spartan 760/8900G OS 55HZ/hatori SAB-55 AR7100r switchglow
700N 8717HV's spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 690 slick V2 V's
90SG 8717HVs spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 710 slick V2 V's
LoveMyTrex is offline        Reply With Quote
Old 10-11-2008, 09:00 PM   #11
Mercuriell
Not sure - think it might be the regular Startus with gearing for the YS engine - the MA site not always the easiest to navigate - check out Ron's Heliproz - he lists it
John
Old 10-11-2008, 09:56 PM   #12
LoveMyTrex
thanks for the link
Old 10-13-2008, 02:54 PM   #13
Laurens
Did you replace anything on the heli yet?
Old 10-13-2008, 11:35 PM   #14
LoveMyTrex
are you asking me? I was just looking at the entire kit, I was thinking about buying a stratus, but I don't have an older one I am looking to convert to a BW stratus
Old 10-14-2008, 04:51 AM   #15
Mercuriell
It's a great kit and strong as nails - did a bad dumb thumb in rotor first doing funnels too low in bad light and aprt from the usual bent shaft and popped links there's very little damage - did the mother of all chicken dances due to the radio getting popped but even so the T700 flyers were amazed at no frame or gear damage.
John
Old 03-05-2009, 06:15 PM   #16
markus d. debose
Default stratus 90 help!
if you can give me tips on setting up my bird? radio gear is all futaba dig. servos 2.4ghz rec. multigov ver.1! please help me set this up! my radio is a futaba t9chp! i need all the help i can get! there are nobody here at these flying fields that know too much about these aircrafts! it would be greatfully appreciated! thank you markus d. debose!
markus d. debose is offline        Reply With Quote
Old 03-06-2009, 08:09 AM   #17
Laurens
What do you want to know? Building and setting it up is pretty straightforward.
Old 03-06-2009, 08:18 AM   #18
wannaheli
MA is out of Sorrento, FL. How far is Clearwater, FL from Sorrento, FL? I would love to visit MA in Sorrento one day.
Member
AMA
Virginia Flyers - virginiaflyers.com
wannaheli is offline        Reply With Quote
Old 08-14-2010, 11:14 AM   #19
Hrob2Ate
John, With the help of your vid's, I just finished my BW Stratus build. Well done my friend, and a huge help as the instructions included in the kit aren't the best. Now its time for final set up of the head and flybar and then the break in. Thanks again for a great job on the vid's...
Hrob2Ate is offline        Reply With Quote
