#21 |
I just found this and was going to sticky it and found it already stucky. NICE SUMMARY!
Rick
Helifreak, the place to be! Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X My products, flown by top pilots around the world, like you! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#22 |
Aaah, you only like it cause your products are in there
Thanks for the kind words, if something should be added please feel free to tell me so!
Boddan "If at first you don't succeed - Try again and again and again..." Belt CP (CRASHED): TP SG-90's, control arm mod, T-Rex 450 main shaft, EK1-0704a T-Rex 500 CF: 5245 on cyclic, JR G770 3D gyro w. 3500G, DX7 |
#23 |
Just be carefull on your throttle curves if you have 6s , 13t, because 90% at 0 pitch could exceed the maximum head speed which is around 2650. The manual states 85% to be around 2630 which is very close, so depending on your blades and setup you could end up with a headspeed that might damage something.
also 5s, 15t could get very close to max headspeed with 90% at 0 pitch.... |
#24 |
wow man thanks.
Jeremy Strickland SAB Goblin USA Team Pilot Questions? Send me a PM! |
#25 |
I ran 100 flat on my 500L motor and I run 90 flat on my Scorpion 1600. I didn't bother taching it which is silly since my friend and I are both point for point on setups and we usually tach everything.
(Compass Warp 360 w/Stock Motor (17t) running from a YGE60 governed at 3200RPM by the Vbar Black, sporting MKS DS95 on cyclic and JR3500G on tail) Proud Field Representative for the following To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#26 |
hi all
i,m getting a 500 for xmas,yoppie i hear a lot about (grounding)the wire to the boom, why is this done and is this a must mod? is this due to the static build up? i had lots of probs with my 450 with like what i think was static build up,but i ws useing ppm,now i have a dx7 pcm and its gone no probs i,m going to use s9257 with metal gear upgrades for the cyclic thay can run at 5,5 bec i believe,any help would be really nice ![]() |
#27 |
well, i am not a very experienced pilot, the only things i have done against static atm is i have soaked my belt in silicon oil and i also have the metal tail case which doesnt seem to build up as much static as the plastic one, cos its more open and ofc metal. but there are quite a few threads here where ppl explain how to do the mods and i guess ppl wouldnt do them, if they didnt have problems ... btw i fly a dx7 too and had no probs at all yet.
#28 |
and this torqe tube will get rid of any probs right? xmas roll on!!!!!!
#29 |
it should solve the problem since the static is caused by the belt... nevertheless i would take a good look how the cost and the part availability for the torque tube is in amsterdam since i read a few ppl had to go back to belt drive and will stick with it, cause the couldnt get enought replacement parts and also the costs are pretty high compared to just a belt crash.
cos mostly you can replace many more parts, so if you are a good flyer with not many crashes or dont care about money and can get your hands on a torque tube and the replacement parts you might want to consider it. so also when you choose your servos or other parts, make sure you can get replacement parts like gear and new boxes before you buy them, otherwise you sit there without replacement parts after a crash... |
#30 |
good point!,well i,m a good flyer,8 to 9 months now,
#31 |
Boddan, nice work. A lot of people have spent weeks of researching for what they need to get a trex 500 up and running the way they want it. Like most people here have said and will agree, you have basically summed most things up and it should save new buyers alot of time and effort.
-Jonny
Spektrum DX7, Align Trex 250se, Align Trex 500cf, Align Trex 600n LE |
#32 |
Thank you for the words J, thank you
#33 |
yes, killer work Boddan! makes it alot easer for us (me) newbie pilots. This static issue has me kind of puzzled as I have a FM radio...
#34 |
Hey boddan great thread there are a couple upgrades you should add there on ready heli just out from align new carbon paddles metal horizontal fin stabilizer and metal servo mount. just to name a few.
#35 |
I'll make sure I update when I get the time!
If you want you could always PM me and write text that I can "copy-paste" basically.
#36 |
you forgot the JR Z3650 for the cyclics
great servos they're metal gear too its like a 9257 with the torque of a 9650 and gear strength of a 5245 without case breakage |
#37 |
and the prize of a...?
I will make sure to add them, only for cyclic?
#38 |
yah
those for cyclic and a G7703D w/ 3500G rock hard combo |
#39 |
you like your JR stuff ey, running a JR radio too?
#40 |
DX7
