| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
#41 |
Thanks The Bum
#42 |
My friend and I both used futaba 3151's and they both eventually went dead in a few months. I recommend some other servo like a 9252 or 9452.
Trex 600CF Trex 600N Pro |
#43 |
A question about the limiter function. Yesterday I went flying for the first time with the MGP installed. I use gov OFF for normal, 1800/std for Idle 1 and 2000/std for Idle 2.
The thing is that I have about 2300 rpm in normal mode. My throttle curve was 10-50-70. Lowered it today to 10-30-50. But I still want to use the limiter function in case thats not enough.. Regarding setup, from what I understand I should set the 3D limiter to on, then set the normal mode to 3D and RPM 1800 to set the limit to 1800. Then it will not hunt for 1800 just limit when I reach that RPM. Is that right?
T-rex 600N SuperPro, OS50 Hyper, Align DS610s, MultiGovPro with Hitec HS-5065MG, Logictech 6100T+6100G, Spektrum DX7. |
#44 |
I'm downloading the vids now. I'm seriously considering this governor for my BW Stratus.
Team Thunder Tiger Europe 4RC.nl, Edge rotorblades, Scorpion systems To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#45 |
#46 |
I just installed new bearings in my os50 and installed the mgp at the same time should I just break it in while flying normal mode and set the mgp below 500 to leave it off in normal? If so what kind of curve should I run it at ?
#47 |
If you only replaced the bearings you don't need to run it in again. If you changed your ring/liner its a good idea to run in the engine again.
#48 |
If I knew that I would have been flying it already instead of waiting for the nice weather. I've had a day or two that I could have flown but waited because I would have been just breaking it in . Thanks for the info
#49 |
Im saving my money for one of these for sure.Im a noob so I have to be sure,this is a gov and carbsmart in one right?
Started the hobby in Feb of 2008 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. . |
#50 |
Yes. And the gov can also be run as a limiter, but the gov is so good you won't want to.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
#51 |
#52 |
just got my aerospire mutligov pro from helidirect..installed in my trex6..followed this vid.made the install and understanding very easy to a T.. thanks Bob...
i notice after programming that is is a Version 1.0.. also Bob's is ver.1.0 some reseach there is a ver.2.0 http://aerospire.com/support_multigov-update.html just wonderin' if i should send it back.. any1 done this ? :o |
#53 |
Version 2. 0 applies to the older MultiGov, not the MultiGov Pro.
As I understand it, the MultiGov 2.0 and MultiGov Pro are very similar in governor functions and operation. The MultiGov Pro adds the mixture control capability.
#54 |
oh i c
thanks pinecone.. ![]() |
#55 |
Can anyone shed some light on this for me ? I made up the temp sensor just like bob and checked it and it worked fine then ordered artic silver . after three days I went to install sensor and when I did the display says it is not connected. I havent even used it and lost a sensor, what could have happend to it ? anyone else had this happen or am I doing something wrong?
#56 | |
#57 |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Yes, but I think kicky was saying that he hadn't even applied any; he had done nothing other than hook it up again.
If that's not the case, my sensor failed between the time I put Arctic Alumina (not Silver; Alumina is non-conductive) and when I applied it to the head. I never did try again, but when I do, I will be using the new sensor with the thermistor on a circuit board.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#58 |
There is a reason they give you multiple sensors.
#59 |
I took off the heat shrink last night and sure enough the sensor was cracked right down the middle so I built another one and checked it and it said the room temp was 22c and then installed with artic silver and rtv for stabilty and checked the temp again. It now says it is 6c, can this be right because the heli is stored in the same room that is 22c . All that changed is I installed it and the temp went way down.
#60 |
when I made this sensor I also used so shoe goop between the two wires but not on the thermistor or even close to it. I hope this will give it more of a fighting chance and hold together better then the last one
