| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
#61 |
My though was that he artic silver could be shorting across the sensor
#62 |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
That may be true with the MGP, but not with the CarbSmart, which is what I have.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#63 |
no artic silver comes directly in contact with the thermistor. This failure happened before it was even mounted. My question now that it is mounted is why is the sensor reading such a low temp ? will this give me a lower reading when flying and possibly overheating the engine. target temp is 105c if the sensor is reading 16c less then what it really is then the temp of the motor would be 16c over 105c
#64 |
Did you make sure the heat shrink was long enough to prevent the sensor from touching the head?
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
#65 |
I got the Multi gov pro and want to add the mixture control.....my prob is o dont know where to get the parts! I have a eflite ds75 servo (Will this work)but no where to mount it and nothing to put on the mixture needle....I can probly make a control rod no problem! any one know where i can this stuff: Servo mount, Mixture needles clamp - or whatever you call the servo arm on the engine!
Trex600, Blade 400 2.4ghz Jrx9303 ::::::::::::::Real Heli:::::::::::::::: MH-53CE Power Plants Mech To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#66 |
What heli?
ReadyHeli has mounts for the Trex 600, 700 and Vibe 50, or you can modify one of them. I modified a Trex 600 mount for my Vibe before they came out with the Vibe version. http://www.readyheli.com/Custom_Heli.../chp-a202n.htm - And they have several different ones. http://www.readyheli.com/Custom_Heli.../chp-a700n.htm http://www.readyheli.com/Custom_Heli...chp-jrv014.htm ReadyHeli carries the CarbSmart mixture arm. http://www.readyheli.com/CSM_CarbSma..._p/csm0052.htm AeroSpire carries the temp sensor. Google Artic Alumina for heat sink epoxy for the mounting.
#67 |
I Got it all on order!
Wow thanks Pinecone for the links and awesome website! Cant believe i didnt know about it....... ![]()
#68 |
Finless,
Was there anything you changed on the advance configuration menu after some 3D flights? Any updates? |
#69 |
Team Taco VP
Nope.... only thing I have not played with is the carb smart system... I left my existing carb smart on the heli so never messed with the Multigov carb system. BUT I plan to move this unit to my 700 as with the colder temps the carb smart is not working well on my 700 so I want to try the multigov on my 700...
Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#70 | |
#71 |
is it possible to use a backplate sensor for the multigov pro? any time i try to instal my sensor with the magnet i cant get it to read without hitting
Jeremy Strickland SAB Goblin USA Team Pilot Questions? Send me a PM! |
#72 |
Yes! The Spektrum sensor will work just fine. I'm running one with my Multigov (non-Pro) and it works great.
#73 | |
Hey Finless, Have you had time to try the MGP on the 700 yet? I am thinking of purchasing for 600 but I am wondering what the "experts" think of the MGP. It looks like a no brainer if you want mixture control and want to replace the el-cheapo align gov. Inquiring minds want to know!
<<450SE V2, CC35, Kong Power 3S 25C 2200, 430XL, 401 w/9650, HS65MG, tail weight mod>> <<Blade MCX with glow-in-the-dark setup, carbon fiber canopy>> <<Yellow 600SNP, 8717s, 770 & 8900G, AR7100, Multigov Pro, Align 2 in 1(used for glow driver only)>> |
#74 |
Team Taco VP
Honestly.... I have not BUT.... it really should work just as good on the 700 as the 600. Understand what a GOV does and so you know the size of a heli really doesn't matter to how a good gov works!
Bob
#75 |
This is weird, I flew my 600 yesterday and the whole time the mixture control was full lean. I landed and pulled out the display to check full lean/rich and it is right. I checked the temp on the diplay and it was saying it was 0c in the garage. How can I figure this one out, because the outside temp was 57 farenheit no where near 0c. should i just set the target temp lower, like 85c and see how it tries to lean or richen the mixture ?
#76 |
How would I know the max rpm it ran after a flight with the MG ver2, not MGP.
#77 | |
#78 |
Just got my MGP yesterday, this is my first gov so I will have to drop my engine to place the magnets. Do I need to put the other magnet (with opposing pole) in also for balance or just fill the other magnet hole with epoxy or just leave it alone? Also does that Spektrum backplate sensor work with a 72Mhz radio system of the JR type?
Thanks, Matt |
#79 | |
I would strongly advise going with the backplate sensor. It won't be prone to destruction in a crash (I destroyed two fan sensors in crashes) and it's just easier to deal with.
#80 |
I watched the multigov videos and Bob states that during the governor test its supposed to turn on at around 20% throttle in normal mode. I have a linear throttle curve and no matter what I do it still won't turn on until the stick is ABOVE 50% throttle. What affects the turn on point of the governor that can adjust this back down where it is supposed to be?
