| X400 and MX400 Ark X400 and HeliMax MX400 Helicopters Information |
finally found some main gear for people who have trouble buying ark helimax 400 main gear.
ESky cp honey bee main gear this works fine, all you have to do is remove the bearing from the x400 gear and glue it in the esky cp honey bee main gear hole, fits perfectly. works fine |
A Blade 400 gear can be fitted with some minor work. It's for a larger heli.
SB
If it's critical, don't worry about it, as long as it fits in the circle of certainty defined by absolute precision, it's more than approximately exact. |
I've been interchanging my Align Trex 450SA (same as se) gear. the main shaft is the same diameter and length. You could even swap out complete rotor head systems. Just make sure you use the correct swashplate 90/120 degree, for your control sysetem.
